Hi everybody,
sorry if I write in english but I do not speak german... I tried to understand some word by reading the forum but is really hard..
I'd like to change original LED Blinker with Kellerman Atto (1.5 watt), I made a test and frequency is too quick.
As written on the glass, original blinker seems to be 3,4 watt BUT on the glass is also written 1,2 watt... this means confusion !
I suppose there is an internal resistor on the blinker itself (from 1,2 watt of the LED to 3,4 watt load on the system), could someone confirm that theory?
So, my questions are:
- Should I put some resistors in series on the blinkers? wich ones (which power), I need if someone knows?
or
- Do I need to change the Blinker Relais? (that seems to be the best solution)
but above all:
WHERE IS LOCATED THE BLINKER RELAIS on CB1100RS?
Please post a picture showing the location of the relais blinker
Does someone can suggest me a relais that fit and works on RS?
Thanks in advance for helping me
Mattia
